Recall Memories with timing via bumps
Hello,
 I'd like ability to recall a memory with timing via the memories' bump button.  Is this possible?  I know you can do this when you are in recording mode for a cue stack...the console previews the look and fade time while you record.  I'm wondering if this could be an optional operating mode?  My users are very non-technical and I'd like to setup a page of memories with looks that they can transition to just by pressing the bump button.  Building a cue stack wouldn't work well because we often don't follow a set order.
I guess I could just operate the board in cue stack recording mode but it would be great if there was a better way and if the buttons didn't flash.
 Thanks for your time,
Mark Wyse
Blackhawk Church, Madison, WI
  • From the cheap seats looking in: would enabling "NEXT" for the memories work for your application?  Seems (again from the cheap seats) that this would be easier to implement for ETC than adding a completely new feature.
    Best,
    John Penisten
    Full Compass Systems
    Rental, Production, Design
    http://www.fullcompass.com
    Phone: 800-356-5844 Ext. 1355
    Fax: 608-831-6330
    "There is nothing either good or bad, but thinking makes it so." - William Shakespeare
