Well, you are not officially a beta tester - although it seems we should ask you to help out!
We are looking in to the issues you have raised. look for a post next week.
I'll be proud to help you.
One more strange behavior :
In stack:
Lets take an example. Your next scene is set to be on stage in 1 min. So you hit go. During the fading, for any reason, you'd like to go faster, so you want to use the crossfader. If you don't hit pause before, the behavior is really strange and quite difficult to explain with my few english words. (it begins with a kind of go back and when you reach the level of the moment you stopped the fading using the crossfader it restarts with the original timing). I let to you try to better understand.
Bonjour,
I'm the product designer of SmartFade and SmartFade ML. I would like to hear more details of your findings using SmartFade. We are preparing an update and if we can solve the problems you have found I would like to help.
Please contact me: adam.bennette@etcconnect.com / +44 20 8896 1000 ETC limited. London.
Je parle le français, à peu près, avec un accent à couper au couteau. Veuillez m'appeler.
