can not start smartfade ml
hi all:
i was testing midi show control function, and i found buttons no response, so i cut off the power, and when i boot it, the console stop at
 ETC SMARTFADE ML
VER: 2.0.0 26 Lib:4.0
in both screen, and all the button no response
how can i do ....
[edited by: mwg at 10:57 PM (GMT -6) on Mon, Aug 25 2008]
  • Seems like your console got stuck in some way. In case it doesn't boot normally, you can force a complete clear of its memory. Then it should start properly.
    Do to this: Hold down the Menu/Ok button while attaching power. You will then enter a test menu with many different tests. Keep pressing Menu/Ok until you have passed all the tests and the console shuts down. You should then be able to start normally again.
    Please note that this will clear all show data from the console. However, since the console is stuck, you don't have any other options, I'm afraid.
