When setting addresses and menu options on a large amount of fixtures, a batch push menu is really needed. I'll call it batch set mode. An idea of the functionality we're looking for is:
On enter Batch Set, select the fixture and ALL possible configuration settings ( I know expanding this is in the works). The settings should probably be in a popup window so they can hide when set.
The main screen would have a calculator style number pad for direct number entry, as well as selection of offset options similar what is available in the existing Create Device screen.
When in this mode, NFC should be always active, and each push should increment the address as configured above, as well as being able to directly key in a new address.
It would also also be nice to have an optional ding or buzz sound effect option on success/fail of the push.
The current approach in SetLight of creating a "device" and selecting then pushing that device isn't really workable when addressing on the order of hundreds (or even many tens) of fixtures. Especially when start addresses and spacing may vary.
