Assign Multiverse parameters when adding a batch of units
Currently there is no way to change the multiverse parameters until after the addition of the units in 2.0.  This has led to a dramatic increase in time spent in the app and on the nfc push to units.
  • Wanted to bump this, as I'm also running into this issue. What could be a quick 2 minute "add a group of lights with the parameters I want, and push NFC" task turns into a 60 minute "I need to manually edit every single fixture individually, and hopefully I don't miss any or mess any up" chore. Any time saved on the hang is lost in pre-work by needing to edit all of the lights on the list.
