I've been experimenting with the #lighthack Arduino project.
I want to send an OSC command from an Eos macro to the arduino.
The macro is just 'Send_String /led1/on' (with the line termination symbol).
When I run this macro I can see in the diagnostics tab that the OSC message has been sent as well as /eos/out/event/macro/1
The SLIP library on the arduino see's two packets. The first one I believe is caused by the Phil Karn packet initializer as it has a message length of 0. The second packet is the /eos/out/event/macro/1.
The /led1/on packet is never received.
I've also tried sending the string as an execution on a cue, that has the same issue.
Has anyone managed to get this to work?
Many thanks for your help in advanced.
Cheers
Fraser
