I see someones created code for a 6 fader wing box, is there any documentation for this like a components list and wiring diagram etc just like Box 1?
No, there is no wiring diagram. I made an improved new version on GitHub. Some instruction you can find as a comment in the code.
The only recommendations for fader is a 10k Ohm linear. There are many versions on the market, you need to choose the right one for yourself.
Eine neue Version 1.3.1 ist bereit auf GitHub. Um z.B. auf Nomad die Faderseite 2 anzusteuern verwendet man initFaders(1, 2, 10); man muss folgende #defines ändern
#define FADER_BANK 1
#define FADER_PAGE 2 // Faderseite auf EOS / Nomad
#define NUMBER_OF_FADERS 10 // Anzahl der Faders pro Seite bei EOS / Nomad
New version 1.3.1 on GitHub. Better initFaders(), which allows you to assign the faders to a fader page
e.g. initFaders(1, 2, 10); controls the faders on fader page 2, this can be done with changing the #defines
#define FADER_PAGE 2 // fader page on EOS / Nomad
#define NUMBER_OF_FADERS 10 // size of the faders per page on EOS / Nomad
I assume you think of Element 1, which have only one button per fader. Have also a look to the Readme.
Using submaster class, no initialization needed:Submaster submaster1(A1, 2, 1); // make submaster 1 using Analog pin A1 for leveler and pin 2 for the fire/bump button
Using fader class:Fader fader1(A1, 2, 0, 1); // make fader number 1 using Analog pin A1 for leveler and pin 2 for the fire/bump button, no stop button
