HES SolaPix 7's & 19's "green flash" on dim.
Has anyone else experienced this? When removing intensity with amber I get a green flash when dimming but nothing green when flashing. Any ideas?
  • Hi
    Thank you for reaching out with a video. I want to get more information to better understand how you are using the fixture.
    A few questions that came up:
    What is the fixture software version?
    Fixture serial number?
    Control console being used?
    Is this happening when the dimmer is used or when a color fade is being used?
    Here to help.
    Kindly,
    Wyatt
  • Hey thanks for getting ack to me. Answers below.
    *Solapix 19xt is ver. 1.0.2 and Solapix 7 is ver. 1.3.1
    Pix19- 5509922030996
    pix7- 5509920050119
    hoeever this is happening with more than just these two fixtures in the video.
    Control console being used? Both GrandMa3 and Chamsys have been tested with this issue
    Both. The video is dimmer. It also occurred during an amber chase color fade.
    thank you!!
  • No problem, happy to help out
    Thank you for all of the information, this is helpful.
    I recommend switching the PMW mode in the fixture settings. This may help mitigate some of the color shift.
    Basically what we see happening with a mixed color is 8-bit DMX values 0 to 255 are converted to 0 - 100%. When fading a mixed color, for instance 100% Green and 50% Red, it is more noticeable since both colors are not at the same level. We can also see this phenomenon with other mixed color combinations as well.
    Feel free to give us a call if you would like to chat!
