humm..... Is yours the magnetic or electronic version? If you do not know, does it take 208V or 120? and does it have the fins on the back of the base?
M version 220 only no fins S version any voltage has fins and a LPS (board only runs SCOL) Studio version (new type) has fins and a LPS ( board runs SCOL and spot)
The problem lies with the board. You cant upload the newest ver of software into an M or S. They have special 'last ver to be used' software. Go any further and it wont be pretty...
[quote=Puffyfish]M version 220 only no fins S version any voltage has fins and a LPS (board only runs SCOL) Studio version (new type) has fins and a LPS ( board runs SCOL and spot)
The problem lies with the board. You cant upload the newest ver of software into an M or S. They have special 'last ver to be used' software. Go any further and it wont be pretty... Actually, the "M" version will do 208, and 240 at 60Hz, and two other voltages at 50Hz . . . there are three taps on the ballast that can be selected internally . . . . . The motor power supply (actually, everything *BUT* the ballast) will take any voltage just like the "S" . . . the ballast is the only limiting factor with the three taps.
