Studio Spot 575 - Issues removing motors
I'm trying to do a complete breakdown and clean of quite a few 575's and am running into issues with removing the stepper motors where one screw on each seems to not want to move, and obviously I don't want to strip the head as drilling it out would be more work.
I'm wondering if a dab of glue is placed on one of them which is causing the issue - either that or I'm just having a run of bad luck with the 14 or so I've tried so far.
Anyone got any suggestions?
  • Okay, i have two solutions to this problem,
    1- Make sure all the glass components are removed, then place the screwdriver on the screw and hammer it and try to unscrew it,
    2- with a small hack saw try to saw a diagonal on the tip of the screw and then use a straight screwdriver to unscrew it, this one should work
    Btw, when the screw seems to be jammed before damaging the tip, try spraying some WD40 on them, and screw them a bit clockwise then unscrew then anti cloackwise.
    Hope i've helped you
    Sevan
  • I ended up getting a nice new compact 14.4v impact drill which seemed to do the trick. Thanks for the suggestions Sevan, all good ideas, but from speaking to High End, WD40 is a definate no-no in the units as it can cause issues.
