Filter calibration is no longer required when replacing filters on your DL.2. Calibration was removed in favor of a hard coded average filter curve to help with ease of use for our users. There are currently a few known issues with the filter code which can cause Filter Warnings and Errors before the filter actually needs replacement. These issues will be solved with our upcoming software release.
Thanks for the post, its good to know users are watching us :cool:
I had a case that after the filter replacement. The filter life out warning message still apear. How can I erase it? Because it bother to my customer. Thanks a lot.
The version 1.2.1.794 is running on the DL.2. Last time I replaced the filter and then upgrade the software. Then the filter warning message appeared. I tried to switched off the preview but the message stilll appeared. Thanks your help.
Have you tried uploading the new the beta version yet? We have made adjustments in the filter code with this beta version to help with filter warnings/errors.
