So i have a rig in in the air, And s-video running up to the DL2 that i have in the air. I go to my console and try to switch to the S video and nothing happens the graphic eng stays in. I thought maybe i was missing S-video to the DL so i put a monitor on the other end of the S cable and saw signal. Im not sure what im doing wrong. Please HELP!!
Do you have the correct Media Folder/File selected on one of your layers to bring up the S-video signal? It should be media Folder 255, File 1. What steps are you taking when trying to switch to the S-video signal?
Also be sure to set the s-video capture relay in the correct position.
On Hog-3 It must be set to "s-video" not to "camera"....not sure if gMA uses the same terminology for the fixtures. Thsi must be done with Motion Intensity set to 00% for about 10 seconds or the relay will not change positions.
Is there a step by step procedure on how to do this? I can't find anything in the DL manual. We're looking at feeding S-vid content to 2 DL.2's using image blend. We have a Full Boar console.
[quote=btalbott;38603]Is there a step by step procedure on how to do this? I can't find anything in the DL manual. We're looking at feeding S-vid content to 2 DL.2's using image blend. We have a Full Boar console.
thanks.
Plenty of info in Chapter 14 of the DL manual....starting p199 of the v1.5 DL.3 manual (essentially same for DL.2s)
