Hello All,
I have a Revolution that is not powering up. I have swapped out the power supply module and the control data module as well as the SCC board... Checked that power is making it into the power module as well...
Any thoughts?
Hello All,
Any thoughts?
Hi RS,
do the LEDs come on at all?
does the S4R try to calibrate when you turn it on?
Can you remove any inserted Modules so those bays are empty and try and power up?
I get nothing, no LED's no calibration.. nothing
Pulled the Iris and RWM and still nothing
Do you have a working S4R to swap its PSU and MCC out with?
Most likely then its a cabling problem - either the connectors
are connected backwards or the cables are damaged?
