Hello All.
I know the Source 4 Minis use a specific type of MR16 Lamp, and I've been looking for where to get those lamps.
Also, I've been looking into, is it possible there is an LED Retrofit style lamp that can be used in these fixtures?
Hello All.
Thanks. Any thoughts Yay or nay in regards to using an equivalent LED source Lamp?
not my area of expertise, but i think it would be hard to find something that as decent dimmability (or dimmability at all) and fits into the fixture both spacewise and regarding optical path.
That may not be a problem, we may not need dimming, we're trying to squeeze more output out of the little guys.
look at these www.soraa.com/.../18-MR16-GU5-3.php
Hey Shadow
Did you try replacing the 50W incadescent with LED?
How did it work out???
Hey I did a while Ago.
I was running these Minis off a Doug Fleenor 8 Channel Wall Dimmer. I can't recall the specific model of the MR16 LED retrofits we used, but I'll try to get it for you later.
