I have 4 ColorSource Spot Deep Blue lights. One light is only producing white lite. I can't get it to display any other colors. The other 3 Spots all do fine but only this one that won't. Could there be a setting on the fixture that is keeping it in some kind of white mode?
You should check what mode your light is set to. You might be in 1-channel mode.
The ColorSource® Spot Installation Guide has the infos how to change it on page 7 of 12
Thanks. For the suggestion. I will take a look.I see that there are approximately 5 different modes that the light can run in. While paired with as CS 40 console, what is the recommended mode?
Along with ueliriegg's answer, I would also check that you do not have any addresses parked, I ran into that issue where I accidentally parked some parameters on
I checked and indeed it was set to 1 channel mode. Once changed, the light is working great! Thanks for your help!
Yes. I realized that when I originally set the DMX and hung the lights it was in 5-channel mode. Once I set them to Direct Emitter mode, I realized that it is 6-channel and suddenly I had conflicts all over the place. I needed to reset with 6-channels in mind and then things settled down.
Ah, glad you figured your issue out!
