Regular Maintenance on CS4 LED unit
Hi
the maintenance for a regular S4 is pretty basic:  clean lenses, clean reflector (carefully), check shutters and lamp base, dust outside (plus make sure all the washers and clips are in place).  I guess it's even more simple for a CS4 unit, since we can't access the LED engine.
we can dust the exterior, but what about the fan:  is it sucking air INTO the unit to cool the Heat Sink, or pushing air out?
A tech here says that we shouldn't allow the fan to spin if blowing canned air into the fan unit to dust it.  "it will build up a static charge."  True or false?
Anything we need to pay special attention to when cleaning a CS4?
Thanks.
Andrew Riter
