hello, anyone know how many Watts is each LED??
The total power consumption of the fixture is 120W. Since the ColorSource PAR has 60 LEDs, each one probably runs at around 2W or less.
The ColorSource PAR uses an RGB-Lime or RGB-Deep Blue LED array, and the entire fixture consumes about 118 watts at full power. However, it does not use discrete high-wattage LEDs like 10W or 20W per diode. Instead, it uses a dense array of smaller LEDs combined to produce a wide spectrum of color.
ETC doesn’t specify the wattage per individual LED because the fixture operates as an integrated LED engine, with multiple diodes working together under software control.
