Power On
Hi
When four Seladors are used, with daisychain.
When one Selador power on/off, other Selador Flashes.
If a DMX output is seen, it will output for a moment.
I think that this is very strange.
Kani
  • Hi Kani,
    Sorry you are having issues.  I would love to get a little more data from you.  What kind of Seladors are they, Serial Numbers would be great.  Are these single cell units?  Which unit in line are you powering off disrupting the others?  How are these being controlled, ie what kind of console.
    If you would like, you can give us a call at 800-775-4382 and we can continue troubleshooting this over the phone.
    Matt Carroll
    Tech Services
  • Hi Matt
    S/N:455853241,455853242,455853244,455853250
    All one cell type(Vivid-R)
    Ver1.15
    Console SmartFadeML
    Power On/Off was performed after console had started.
    Even if it checks by DMXter, two or more channels are outputting.
    Best regards,
    Kani
  • Hi Kani,
    Thanks for that info.
    So a Selador unit will turn itself on for a moment to test its' LEDs when it is powered on.  This is normal behavior .  Is this the flash you are talking about?  Are the units working correctly otherwise?
    Are you losing control to a fixture when another is turned on, or just curious about them flashing on power up?
    Matt Carroll
  • Hi Matt
    I understand when Selador power on to test.
    However, since other Selador is testing simultaneously, it is made the problem.
    Best regards,
    Kani
