Have a couple of Lustr2 that are flashing randomly whilst dimming. Usually stable at 100% what part would it be card or PSU? Thanks
Are you certain that this fixture is patched correctly? If your fixture profile has a non-strobe parameter where the fixture thinks strobe should be, it may be engaging it inadvertently--this is a common indicator of a patch error. If you know the fixture is patched correctly, it is possible there is a hardware failure of some kind. I would lean towards the control card, but it is not impossible for this to be a problem with the power supply as well, so you would need to swap parts between fixtures to know for sure.
