thanks for the quick reply I now immtoo vedio converter to convert my dvd's to mpeg2 i'll check it out more to see if i can take a peek at the frames, i'm also having the same sync problem with my axon even with the stock content?
ok i'm at home now i'll be going to theater soon, i'll get back to you with those info: the problem i'm haves is when i collage both sever they play out of sync it seems as if my slave is run slower
Actually, the master server does not need to have any settings on it related to sync in order for network sync to function. The only requirement is that anything related to playback (folder/file selection, play mode, in/out frame) is the same as that of the slave servers.
The issue seen here is due to a bone head move of mine :dunce:. Sync was tested and verified on the DL fixture, and I sort of assumed that it would work on the Axon. And we all know what assuming can do...
Axon sync is fixed in the 1.4.3 software that we just released Monday.
DOH!! Well, there you have it!:friday: I've always just included the master server in the sync type when I use it.
Now Matt....why are you trying test all that software all by yourself when you've got all of us out here to help you if you need it? On the other hand 1.4 has been out almost a year already.....I'm surprized it took this long to find it. ;)
