Hi Rod, PixelMad directly controls fitures using DMX sent over Artnet protocol. What exactly are you trying to use with PixelMAD. What is the make and model of the fixture you are trying to use?
Hello Leah, What I was thinking of doing is to run chroma-q color blocks DB4s. These can run in RGB mode and also HSI. HSI mode also includes the extra control channels to allow you to use the in-built effects. What I was wanting to do is control the DB4 by both pixelMAD and normal DMX control by merging 2 different DMX sources together. However for this to work it would require pixelMAD to output HSI dmx and not RGB dmx.
Robin (not Rod.. that was a typing error when I joined the forum!!)
