Cat6 will work, but is vastly overspecced for a gateway.
Anything Cat5e or above is suitable.
I know this is late for the discussion, but if you are adding infrastructure to a building, it isn't a bad idea to consider future upgrades. Infrastructure is the hardest to replace physically. The cost difference between installing Cat5E and Cat6 should be considered to determine if the extra cost is worth the expense based on projected use and expected life time of the infrastructure.
