I have a dmx 2 port gateway and it receives ports 1 and 2 from my Jands Vista. How do I program this node to receive ports 2 and 3?
Using Gateway Configuration Editor or GCE <http://www.etcconnect.com/product.overview.aspx?ID=20370> from a PC on the lighting network, you can change the input universe from 1 - 2, 2-3 or what ever your needs are at the moment. This applies for a net3 system.
If the facility is running net2, you'll need Network Configuration Editor <http://www.etcconnect.com/docs/docs_downloads/console/Network-Configuration-Editor-(NCE)-v431.zip>
