DMX-RDM One Port Ethernet gateway problem
Hello
I`ve got a problem with some of our DMX-RDM One Port Ethernet gateways.
We have 10 and I`m in the process of updating all the firmware via UpdateApter.
7 of them have no problems, show up on the network and have been updated.
However, 3 of them don`t show up on the network, even though the power and Network LEDs are showing.
Obviously, I can`t access them to check the firmware or upgrade it.
Any ideas on what could be the problem?
Many Thanks
Simon Denman-Ellis
Assistant Technical Director
Le Rosey Concert Hall, Switzerland.
  • Hi Simon,
    Are all these One Port Gateways the same exact Version of Hardware, meaning they have three LEDs on them?
    If so, then its possible that some have an IP address that isn't in your subnet. Please open the Concert Software and
    then you have the function under OPTIONS -> "Find unreachable devices." This will find the Gateways with a different subnet.
    Then you can give them an IP in your subet via that function, and then you can find them in UpdaterAtor.
  • Hi Corey
    They all have 2 LEDs...1 for Network Data and 1 for DMX Signal as they are the PoE versions.
    I`ll give the above information a try and see what happens.
    Many Thanks
    Simon Denman-Ellis
  • Thanks Corey, Worked like a charm.
    Whoever set it up used the wrong Subnet and the wrong Gateway.......
    All sorted now. Thanks for your help.
    Simon Denman-Ellis
  • Good Morning Simon,
    I am glad that worked! -
    Were the Subnets of the Gateways 169.x.x.x ? If so, that means the Gateways did not find a DHCP Server when they came on the first time, and took a random IP in the range 169.x.x.x - this allows them to at least react to sACN Data, and Output DMX.
    Just to let you know, if the Gateways only have 2x LEDs (NET, DMX) on the front, and not 3x LEDs (Power, Network, DMX), These are only sACN/DMX Gateways, but do not Support RDM.
    You can contact us directly in Holzkirchen if you have more questions.
