Hello all!
I seem to be unable to control other features than the DMX adress of the Coloursource PAR using RDM. I have a couple of lamps mounted in hard to reach positions and would like to change the mode to Direct -6channel mode. They are currently in RGB mode. I am using a DMX Cat. Of course it might be possible that it is this product that is causing my issue also.
I am considerng doing a factory reset (which seems to be accessible remotely) since it seems someone has changed their behaviour to put out light when no DMX is present -which is not a function I want. But I am unsure what mode they will start up in after that.
Any suggestions are welcome.
Peder
