Response DMX in disconnecting.
Hello!
I have a Response gateway with 4x DMX in and I have a problem where the gateway looses the all connection when I plug in a xlr cable. I then need to restart the gateway and all works fine. but next time I plug in a cable it goes off line.
With off line I mean I can't see it in concert, and all inputs flash in the display like it not geting signal. I unplug the network cable (that powers the gateway over POE) and when I plug it back in it works just fine. But the green and blue LED is acting normal when it goes off line.
I had problems with my OUT nodes having wrong settings on the Termination switch. can it be something like that here to?
Johannes
