I have an ETC Response, with four dmx inputs. I need to make them work like exits. I made all the settings in the gateway. Instead of red LEDs, green LEDs blink. but I don’t understand how to solder the connector. in theory, I should solder pins on female mirror. That's exactly what I did. But, the green lights continue to flash, although they should light continuously. it means that the gateway does not see the device. tell me, maybe I'm doing something wrong? It seems to me that regardless of the network settings, if the gateway sees the device, it will stop blinking with a green LED, and will light continuously. or am I wrong?
