Hi All,
I apologize if this has been covered before, I searched the topics first and didnt find anything...
I have a fresh out of the box Net3 2 port node to go along with our new Ion console. I've gone into the Network Settings on the Ion Shell to configure the node, but I'm not having any luck. When I use the Network Services to attempt to the bind the node, I get the following message:
"Error! Can't bind the BOOTP port!
Either you do not have necessary privilege or a BOOTP daemon is already started or IP configuration has changed.
Bind returns error -1, GetLastError 10049"
After which the Ion locks up while trying to find new devices. I set up a wireless router for the iRFR with no problems, and I have tried to bind the node with it plugged into the Ethernet hub as well as directly into the back of the console. I've confirmed the Ethernet cable is good.
If anyone can fill me in on what I'm doing wrong, I'd appreciate it!
