I've had an issue with one of my two Net3 4-port Gateways not showing up on GCE, pinging, or appearing on the "About System" list in About on my EOS. This was correctly diagnosed as being down to an old software version - the one that doesn't appear is on Gateway v2.x and the one that does is on Gateway 3.x.
Clearly I need to update the software on the older Gateway, but it is permanently installed and inconvenient to get to with a Laptop (and as mentioned not showing on GCE through my Console). How reliable is the "Hold Button 5 sec to Download Software" function, how long will it take (I got bored and reset after 10 minutes of waiting, though it said it was downloading at the time), and is this a good idea at all? I assume that it is downloading from my RPU as TFTP server based on the IP, but will the RPU have the latest Gateway Software version already (by dint of running on it's own most recent version, EOS v1.9.6), or how could I check and update this?
Thanks in advance, would just be really handy to update over the network if this does work reliably!
Ric
p.s. Release Notes for v1.9.6 insist on Gateway software v4.0.0 for ETCNet2 operation. This is slightly confusing as my Gateways are running on the latest Net3 version which is 3.x. We're not using Net2 so it's not an issue, but the release note being a little misleading (if running as Net2 a different version number appears?) may be causing more Support calls than necessary!
