Hi all,
A spooky thing is happening...
There is a compagnie with a console sending dmx into our gateway.
We use an AIP to send the data (adr 100) to sacn 36. This is not working.
We tested it on a simple dimmer and the dmx is coming thru. If wo put it back into the gateway it does not got picked up by the gateway (net 3 response 4-ports)
With the dmx output on the ion it works. But with the output of the compagie it does not...
Where do i need to look?
With regards
Gijs
Setting up an AIP can be a little bit tricky.I run into this nearly every time ; )
Make sure to click the "AIP Disabled"-Button first.Then your Menu looks like this:
And from here on you can continue.
Make sure to uploade the changes to your Gateway.
Hope that will work for you.
Thanx mathilda, The setup of the AIP works as we use it a lot in our theater. But the problem is that it working with dmx from an ION and it isn't with dmx from Qlab. Wile they both send out data as we tested on a simple dimmer...
How do you send DMX from QLab? Maybe the problem is the DMX speed of the sender.
Isn't that a standard speed? And if not is this convertable? It was a old node. 3 pins out so not that fancy.
Maybe the old node doesn't follows the standard.
