Smartlink power supply with Smartpack wall mount dimmers
When I use 3ea of Smartlink 5 button stations with Smartpack wall mount dimmers( 2ea of SL1210W, 1ea of SL620W),
do I need only one Linkpower Supply(like SL1210W-LPS) for the system?
or do I need linkpower supply for all three each dimmers?
There will be smartfade console, too.
I'd appreciate for any advice regarding.
thank you!
  • Hi Doo,
    here is the Smartlink PSU Install Guide Link:
    http://www.etcconnect.com/docs/docs_downloads/manuals/LinkPower_Supply_Kit_SetupGuide_revB.pdf
    You may have only one station power source on the SmartLink network. This source may be either the LinkPower Supply (S-LPS) or a SmartLink Station Power Module (S-SPM) which powers up to 16 SmartLink stations. As well, you may have up to four SmartLink host products in a SmartLink system. One SmartLink host product (SmartPack, SmartSwitch, Unison DRd with SmartLink or Sensor + with SmartLink) in the system must have a LinkPower Supply or Station Power Module installed for wall station power.
    Your system above with 5x Stations and 3x Smartpack, needs just one PSU.
    Have fun!
  • Thank you, Corey!!
    It's all I need for.
    thank you, again.
    wish you the best!!!
