Windows 7 with XP Mode and SLTA Manager
I recently acquired a new Dell Latitude with Windows 7 Pro with XP Mode.  All of the Legacy software for Unison has been working fine with Windows Virtual Machine running Windows XP Pro SP3.
I then acquired a docking station with a DB9 Serial Port.  Device manager lists the port (COM1) as working properly in Windows 7.  I read a few tech docs and calibrated the Virtual Machine to use COM1 and to send a modem take control command with an "AT" prefix (whatever that means.  The Windows support document was a little vague using terms like "named pipeline.")
I have not been able to get Virtual Windows XP to connect successfully to the SLTA-10, but I also have not verified that the serial port on the dock is functioning properly from Windows 7 in the first place.
So my requests are two-fold:
Does anyone recommend a particular TelNet emulator for Windows 7 with which I can send string commands to another device (Paradigm ACP) and confirm that the port is indeed functional?
Has anyone successfully configured an SLTA-10 with Virtual Windows XP and has suggestions to help me connect?
Brian
