0-10V circuit in DRd with D20
The theater I volunteer at recently had a construction project that replaced some of the lobby lighting.  The new (non-ETC) fixtures utilize 0-10V control.  I was surprised to see in the DRd rack that those circuits still have D20 dimmers installed in them.  I thought that any circuits that utilize 0-10V control should also have an R20 module installed.
Is my understanding wrong, or did the installer make a mistake or take a shortcut?
  • It's likely they are using the 0-10V card inside the DRD rack for the dimming control.
    If the power supply/ballast is being powered by the D20 that's another story.
    If you 0-10V light is on, and you physically breaker off the D20 does the light go off in the space?
    There's always a chance they landed the old circuit from the DRd rack into some panel board?
    And yes a CC20 or R20 would be recommended, R20 being preferred.  Does a D20 work, sure for a bit, but you are still going through the choke of the dimmer and the driver is getting a clipped power signal, which overtime (basically a little mini electrical hammer hitting the electronics inside the driver) is going to cause issues to the 3rd party driver/ballast.  Could last 2 hours, 2 day, 20 years, you never know.
  • This is exactly what I was thinking.  Thanks for the input.  I'll see what details I can confirm.
