Is it possible, for me to purchase my own Bluetooth Echo Access device, connect it to a Client Echo System, and use it to setup the Zone Controllers and Control Stations, then remove it from the system. Will the system retain the programming, so the client uses control stations for the system without changing through the Echo Access App, or does it have to stay with the system?
