I'm new on the CS20 with LED PAR (RGB) and found the tap mode.
When I save a playback sequence with fade in and fade out each 0 seconds (no fade) and press the tap button plus the flash button then I have a fade effect from one step to the next. This setting is there until I restart the console. After the restart the fade effect is away (as wanted). After I press the tap button + flash button again I have the same effect as before.
Is this a bug or a feature? I want to edit the speed of my own chase with the tap button but without a fade effect.
I hope you can help me because this is not very nice and I'm thinking about my money back guarantee.
Thanks in advance.
Jan
