The defaults from new install of both should work together on the same PC.
In case some of the defaults have been lost:
In ColorSource AV offline editor:
Open Setup (cog) > Network tab:
Make sure something is patched and turned on so you have something to see in Capture.
In Capture 2023:
Tools > Options menu, Connectivity tab, scroll down to sACN section:
In Project > Universes tab:
It should end up looking similar to this:
Does ColorSource AV offline editor work for Mac OS ? Impossible to get a protocol sACN out of there ! So enter in Capture 2022 ? Please Help.
Hi! Thank you for your answer! I can get it to work on a pc or from pc to mac. But not if I have both programs on a mac. So I think the problem lies with combination colorsource and mac. Have you any idea if that works?
Thanks for clarifying that you're running on macOS.
You're correct, at the moment the macOS offline editor doesn't output to Capture.
This is known issue CSCON-48676 - Mac Offline Editor does not support connections to a local visualization software.
I've added a note to this that you've encountered the limitation.
Super! Thank you!
Can someone please explain if ColorSource20 Offline Editor (NOT AV version) will connect/work with Capture Student visualiser?
Run the Windows offline editor in an AV mode to enable output to a local visualization package.
The showfiles are 100% compatible.
The CS20 will ignore any accidental use of the AV-only features such as console Universes 2 thru 5 or VideoToy.
Hello
does now in 2025 the macOS ( 14.8.1) offline editor output to Capture?.(On The same mac or Ipad)
Thank You Richard. does this work the same in Capture Student edition? and if so MUST I first build a scaled set and place fixtures that are in the CS20 ShowFile OR is there a default viewer of sorts? ( BTW the Capture Student EDition DOES show the Universe tabs and Network tabs as you illustraed 2 years ago but I cannot yet see a visualisation from CS20)
