[Clear Changed] hidden dialog?
Is anybody else finding [Clear Changed] a bit tricky? I don't work in Changed mode often, so don't know if this is a known issue or if I'm just mashing buttons badly. After clearing a parameter or set of parameters, I can't clear another set, change the channel selection, encoder mapping, whatever, without hitting [ESC] first. Info box shows "[X] channels selected" which vanishes upon ESC, without the channels actually deselecting. Is there a hidden dialog, and if so, can I avoid it?
Version 7.1.1.9.0.35 on a Cobalt 10.
  • Hi Anne -
    Can you try putting the Set/Clear Changed softkeys onto a couple of master keys and see if using a hard key variant of those commands makes them behave a little better? If they do, then I expect there's some oddness happening in the softkey area that's creating the "held key" situation.
    Thanks for the report!
    Sarah
  • hello
    maybe you would use Refresh FCB to reload your attrib state. Set changed is a tool t force the record of any attrib that you haven't change. Clear changed hide the attrib change for recording. these 2 functions is another way to work in changed mode, you can use Mask function but it is another tool.
    The better way with Cobalt is the active mode, you will see all right attrib states in each preset any device work. and your great tool is Mark to force attrib Rec (like setchanged in Changed mode !)
    working with changed mode is for people who master the tracking concept.
  • With [Set Changed] and [Clear Changed] on Master Keys, clearing and setting via the hard (parameter wheel or FCB) keys works fine, but [Master Key] & [any device control soft key] is hit or miss, mostly miss. I haven't been able to reliably set and clear with any [Set/Clear Changed softkey] & [ softkey] combination.
    pilou, when programming Cobalt I almost always work in Active mode, which I like, but I am trying to get out of my comfort zone a little and explore Changed mode.
