Cobalt and Kabuki
Hi all.
We recently bought a Gerriets Kabuki G2 30-3 system and from a day to another someone decide that is a job for the light operator to release some things on stage during the play. I saw that we've got this template and said that it isn't a problem to do that. But, like almost of the times, I spoke to soon. After we mount and plug in everything I went to the console, Congo Jr. Cobalt v7.1...., and try to fire the Kabuki Channel 1 and on the Gerriets consol the channel 2 was fired. I try to fire another one but nothing happens. Only Gerriets channel 2 is fired.
The Gerriets console Is DMX 1 and I'm using universe 2 on Congo. I try to change the DMX and even the universe on Congo but when I manage  to fire something is always channel 2 of the Gerriets console.
Can someone guess what is the problem????
Regards
Pedro Alves
  • the last time i worked with the gerriets kabuki (quite some time ago), i found that by DMX i can only "press" the Fire-button, but not choose the circuits. i had to manually choose which magnets i want to open (with the switches at the gerriets console) and then instead of pressing the fire-button locally i could do that remotely.
    if it's a cobalt issue, i can't help you, and i don't know if gerriets changed its product, but maybe this will help you.
  • From the manual (printed 2008)
    "The control unit is only a single channel DMX interface. Multiple circuits can not be fired independently via multiple DMX channels. The individual channel must be selected (turned on) to fire via DMX."
  • Hi jolsson
    Thanks for the link. I have it on paper but nobody knows where is it now so this will be a good thing to save.
    I've already got to use the Kabuki with Cobalt but I think the problem that I have until now is from the Kabuki and not the Cobalt software.
    Has I told before we've got a Gerriets Kabuki G2 30-3 system and on Congo Jr (Cobalt v7.2 beta) we have the template for this system. I manage to select each channel of Kabuki but not fire them. After some days of brain storm I use the template for the Kabuki G2 30-6 and it wokrs fine. I can select the Kabuki channel I want to use and fire whenever I want. So I think the problem is from the Kabuki system, maybe it came with only 3 channel but the software/hardware inside is the same for 3 or 6 channel.
    The bad think is that for the G2 30-3 we only need 4 DMX channel and for the G2 30-6 we use 7 DMX channel and 3 of them we never use.
    Again many thanks for your link
    Best regards
    Pedro Alves
