Intensity control in device template
So I have these Chauvet Intimidator LED Wash 150 units... Running Cobalt on Nomad for this show.
The included template doesn't function completely accurately, so I've been fussing with it to figure out what's going on, and the first problem is the address assigned to dimmer doesn't actually function, and there's a second dimmer address. So I switched the intensity to that one and I can make everything function.
That said, the dimmer address doesn't work properly because it's set up like this:
0-4 Off
5- On full
6-127 Dim from full to 1%
128-254 Strobe
255 On full
So the big problem is this was designed by a crazy person, but what I'd like to do is figure out how to map the Congo intensity channel to just 5-127 values on that channel - I don't care about strobing, I just need to be able to fade it out without having to fuss with every fade... it's an RGBW color mixing LED unit so I can fade the RGBW full to zero if needed, but it'd be much easier if I could get the intensity to map properly.
Help?
  • Hi Mark,
    Is it this unit?
    www.chauvetdj.com/.../
    If so which mode are you in, 6 or 15 channel mode?
    In 6 channel mode It looks like the dimmer (dmx channel 5) should only work when the shutter (dmx channel 3) is at OPEN (dmx values 004-007 or 216 -255). Other values for the shutter look like they'll do variable strobing.
    So the setup would be, Shutter to OPEN, then dimmer will work.
    Cheers,
    Ric
  • 15 channel mode; I havent looked at 6 ch...
  • Yeah 6 ch mode means pan and tilt have 8 bit control which is not an option. That is indeed the manual but the problem is the manual is not completely accurate to reality, which is why the default profile doesn't work.
  • So I solved my problem: I set both 'intensity' channels to other beam categories and then just put the RGBW channels on 'fade with intensity' settings so the colors create an artificial intensity value. Doesn't fade quite as smoothly as the shutter but it's pretty close and still gives me intensity control without having it start to strobe when I fade in and out. There might be a better way to map the half-channel that is the actual dimmer, but for this show at least I have a solution.
  • I've seen combined Intensity and Strobe before, but that is a whole new level of crazy!
    At present the best solution is to use FWI as you've found.
    The library template matches the fixture manual Ric linked to, so it would appear that the manual is bogus.
    Chauvet say they've discontinued it so I guess the manual is going to stay wrong.
    Could you send us a photo of the fixture's nameplate (so we can be certain which one it is), a copy of your working template, and any other notes you have on what it really does?
    Best email address is Cobalt (at) etcconnect (dot) com as usual.
