Hi Chad -
The Color Picker in Congo is an input method that applies to CMY parameters of color-mixing moving lights. It uses mathematical formulas to mix CMY systems to the color you pick from a color wheel. Congo does not use calibrated fixture templates, meaning Congo doesn't know what L201 is or how to mix a specific fixture's color system to that color.
Our other control system - Eos - does use the calibrated fixture data and does have a color picker more similar to what you describe. It is our hope to add this capability to Congo in a future version, but I cannot tell you when that might happen.
Thanks for your question!
Sarah
Absolutely.
In the mean time, if you do have access to WYSIWYG, you could use the Autofocus functions with Congo to get the values from the WYG color library for your fixtures. This would require the WYG Drivers for Congo, available for download from the main ETC Web site.
Thanks -
Sarah
