slowing movers down
hi ya. i was wondering if anyone could help, i have plotted some movers in to a cue and they are moving around. However i want to change the speed at which they are moving. how do i do this?
  • hi ya. i was wondering if anyone could help. I ve plotted some movers in to a cue, and they are moving around, however i want to change the speed at which  they are moving, how is it possible to do this?
    thanks
  • you have to use focus time. (value) then FOCUS+TIME. FOCUS+DELAY works as well.
    If it is a long time and movement, some fixtures have a "pan/tilt speed" function, which you have to set to get smooth movements, but it is necessary only for really long movements at really low speed. Does this help you?
  • it does make sense, i think, so when im in the cue, capable them all and then press TIME to get them to change speed - is that right?
  • Not quite, but close!
    There are a couple of ways to do this:
    • First, check that Set Times To is the way you like it:
      • "A" - current cue
      • "B" - next cue
    • Type a number (in seconds), hold [FOCUS] and hit [TIME]
      •  This sets all pan/tilt movements in the chosen cue to use that time.
      • You can also use [FOCUS] & [DELAY] for delays, or use [COLOR] or [BEAM] in place of [FOCUS] for those attributes.
    Alternatively you can use the Times Editor:
    • Hold [MODIFY] and hit [TIME]
    • Make the changes you want!
      • You can open a list of individual attribute timings from here if you want to make particularly complex moves.
    [edited by: Richard at 10:18 AM (GMT -6) on Wed, Mar 12 2008]
