is it possible to set the Congo to Tracking mode as opposed to the Cue ONly style of recording that it seems to default to? i've loaded a show that was written on a GrandMA but it seems to only have loaded the change in channel levels and not tracked thru levels from previous cues - the issue also arises when i modify cues - i'd like to track the changes through until the channels receive a new value later in the cue stack - surely this is possible on the board but our ouse programmer is not familiar with the function and this is the first encounter i've had with the Congo - we've opened up the Track Wizard but its seems i'd need to know what cue the channel later changes in order to utilize this function - is it possible for the board to do this automatically similar to Tracking Mode on all other ETC consoles? thanks for any and all help
