Channel Times
Hi all,
Can anyone tell me if its possible to delay a channel or group to fade or fade in. At the moment Im putting a follow on cue to fade these channel or group but is there an easier wa to do this.
Thanks Carl
  • Yes indeed it is!
    Two methods:
    1. Use the {Ch Delay} softkey under {Times...}
    2. # [Ch]&[Delay] shortcut
    These shortcuts use your "Set Times To" A/B option to determine the sequence step they apply to.
    To set these:
    • Select the relevant channels by any method.
    • Type the number of seconds to delay
    • Hit {Ch Delay} or [Ch]&[Delay]
    • You can then give the timing a name to recognise it by - or hit [Modify] to leave it as default.
    • To set a fade time, use {Ch Time} or [Ch]&[Time]
    If you don't set a channel fade time, it will use the main crossfade timings.
    [edited by: Richard at 7:45 AM (GMT -6) on Tue, Oct 02 2007] [edited by: Richard at 7:44 AM (GMT -6) on Tue, Oct 02 2007] [edited by: Richard at 7:42 AM (GMT -6) on Tue, Oct 02 2007]
  • Hi Carl -
    Check out Channel Times in the manual for details, but put simply, you can apply a separate fade and delay time to any intensity or moving light parameter for any channel. For intensities, this can be done live by selecting channels and pressing # [CH] & [Time]. You can then enter a text label for the time group. Be aware that this timing follows the 'Set Times To' setting (A or B). To apply a delay, it's simply # [CH] & [Delay]. You can view and edit these time goups in the Ch Time column in the Sequence List.
    To do a similar thing for parameters, you can do this live by selecting channels and using # [TIME] & [FOCUS] or COLOR or BEAM or wheel keys, or by editing directly in the Preset Attribute Editor (# [PRESET] & [ATTRIB] to open this tab directly).
    I hope this helps!
    Thanks -
    Sarah
  • Hi all,
    Doing times for FBC was no problem but my mistake I was doing was not keeping the channel, so I was pressing # delay instead of # CH/ID then time in which I wanted to delay, so I was always getting 48 sec delay - Doh !!!!
    Thanks for all info though next time I want be as lazy and Ill hit the ? key, worked out problem the night when I posted this it pays to just press what you need it mostly works out that way but it was going my head in so I had to post it :)
    Thanks again
    Carl
  • Hi all,
    Thanks again
