Hi
Is it possible to load in just a new fixture library and not a full software update? Where can I download the most up to date library from?
What I'm actually after is a template for a Chauvet ColoRado1 Tour 10 channels if anyone has one!
Cheers
Hi
Cheers
I don't know about the fixture library, but you can load a template from a play file.
I keep a play file of fixture templates that I have tweaked to my liking and load templates from that play file and not the library.
You will use the import function to bring in the templates to your current play file.
Hope this helps,
John
At present it is not possible to update just the fixture template library, you will need to update the console.
I've looked in the latest release v6.1.0, and the Chauvet ColoRado1 Tour is in the Extended library for v6.1.0.
v6.1.0 fixes many bugs and adds several new features, particularly for live busking situations, so I would very much recommend that you update to v6.1.0 at your earliest convenience.
