objects are missing glTF
Hello!
Runing EOS 3.0.0 build 389
I have problems with the .gltf and .glb files from capture. tried both of them.
they want to scale it down. it say the original size and then propose to scale it down by -x10. Should be 1:1 as default?!
one other problem is that objects are straight out missing. if you open my files on a pc you see the main curtain, but not on my GIO.
I also have problems with the beams not showing when they hit the floor. they just fade out. If I pan up on my backdrop I see the shapes, but not on the floor. (I have disabled the view of the default floor to get the model to show properly)
Files of show and modells:
to etc ESTRAD.zip
Estrad höst 2020 2020-09-26 20-47-44.esf3d
