Does the vectorworks augment3d plugin work on Vectorworks 2022? I don't want to upgrade if it doesn't, as that's a pretty important part of my workflow now.
Thank you. I did read all of that but it turns out the instructions in the 1st folder say to NOT unzip before installation and then once you do unzip the PDF in there says unzipping is needed. I appreciate your help.
