Hi All I need to put a top level of 90% on our house lights. For the life of me I cannot remember how to do this. Any advice please
Many thanks
Baz
Many thanks
Baz
two ways, both in Patch (there's a third way in Park, but i think for your case, Patch is the way to go):
- Patch>Attributes, select channel, Proportion 90 Enter
or
- create a curve that has Input 100 = Output 90.
- Patch Attributes, select channel, Curve x Enter
Thank you so much. I will give it a go.
Proportion 90 will evenly distribute the 90% change (so if you set your lights to "50%", they will be outputting 45%). So will Curve > Input 100 = Output 90.
IF you instead just want to set a "cap" of 90%, but keep other output values normal, use the Curve method and also set Input 90 = Output 90. That will "flatten" the final 10%, while the rest of output will be normal (50% == 50%).
