hello, i have a weird problem. i use a ion xe as backup and another one in master. i updated both of them with eos 3.1.2. In the backup (in which we work most of the time) , a few days ago, as we had a doubt with our vl fixtures, i updated all the fixtures show (show built on eos 3.1) and the result was very strange: my tw1 swapped their appearance for generic par led, my down lights replaced by profiles, and other stuff. but the same show appeared right in the Master and in my computer. The only way i found: reinstall (repair) eos3.1.2 in the backup, and everything went good. then few days later, same stuff, still only in the backup. i installed-repaired firmware again, bug fixed. Yesterday same again. i did the operation again and took a log file of mybackup. Since i made an upgrade of all fixtures, this happens sometimes, and only in the ion where i upgraded fixtures. Anyome with same issue? does someone from etc want the log file ? (as everytime i install-repair firmware again, not sure if the log file can keep a trace of this, and even if i gave a copy of my show from eos backup, pretty sure fixtures would get their right appearance in any other system)
Hey Passa! Please DM me a copy of the showfile and the logs you have saved and I can take a look.
passa said:everytime i install-repair firmware again, not sure if the log file can keep a trace of this
Just to let you know - starting with V3, Eos software's log files do keep track of installation / re-installation of software. Upgrading and downgrading your Eos version does not destroy any of the log files, but they do eventually "age out" and get deleted, depending on lots of factors.
For troubleshooting this issue, as TJ says, we'll need logs from the Primary and Backup, plus the showfile.
Is the fixture library the same on master and backup?
sstaub absolutely, they both have the V3.1.2 firmware included library. (and my computer so). I finally managed to send both logsfiles from master and backup to T J Hill, he should have a look soon (at least i hope),
Matt Pumplin thanks for the logs memory explanation
Thanks Passa for sending me the logs. For those following we found a solution by reinstalling v3.1.2 on all desks in this multiconsole session. We will see if we can find a reproducer of this problem
