Hi guys, just wondering whether you are planning to release OSC support for commands like Staging Mode, XYZ Focus Enable/Disable or fixture position in the nearby future?
Loving the new EOS, good job everyone
Luis
Luis
/eos/key/XYZ_Format
/eos/key/Staging_Mode
/eos/key/staging_mode or /eos/key/Staging_mode work. Send it twice to Clear Staging Mode
/eos/xyz 1.0, 0.0, 0.0 will set the currently-selected channel to position X=1.0, Y=0.0, Z=0.0
/eos/chan/1/xyz 3.0, 2.0, 1.0 will set Chan 1 to position X=3, Y=2, Z=1
>>Note: this position is *always* in Meters, for consistency.
/eos/cmd=Chan 1 XYZ_Format Disable# or /eos/cmd="Chan 1 XYZ_Format Enable#" should change that setting. Note that it does need to be terminated, with the #.
Great, this works like a charm. This leads me to another question: is there a way to retrieve the position of a fixture? (some sort of /eos/out/chan/1/position or similar)
It's not currently possible to get the XYZ focus of an arbitrary channel. You can receive the XYZ focus of the currently-selected channel using /eos/out/xyz:with a result like
/eos/out/xyz, -0.500(f), -10.318(f), 0.000(f)
Thanks Matt, I meant the XYZ position of the fixture in Augment3d rather than the XYX focus but I've checked and it is possible to write Position and Orientation in the command line via OSC so all sorted (I thought it wasn't possible as they're not yet in the OSC Keys in the Manual along Staging Mode or XYZ Format)
The manual should updated for v3.1, there are also some other items (e.g. filter) which are missing.
Hi sstaub could you be more specific about items that are missing in the manual? For instance, I see Filter in the manual, but maybe I'm not thinking of the same one?
I mean the OSC cmd "/eos/filter/add", also the new commands for 'xyz' and key names for 'staging', described in this post.
The rules for parameter names and key names should better explained, like you did in another post:
- the names are not case sensitive
- you can use a space instead an underline
- use '\' (backslash) instead of '/' (slash) when using parameter names in the OSC address
- e.g. for Softkey 1 following is allowed
- "Softkey_1"
- "SOFTKEY_1"
- "SOFTKEY 1"
- "softkey_1"
- "softkey 1"
Ah, I understand now. Thank you for clarifying, and I see this is a request you've made in the past too.
For the time-being, the most-up-to-date reference is a combination of the v3.0 manual (online here: Open Sound Control (OSC) ) and the GitHub page here: ETCLabs/EosSyncLib: UNOFFICIAL - C++ library for accessing Eos show data in real time "Supported OSC Commands"
We agree there needs to be comprehensive documentation around using OSC in Eos. In the meantime, you are always welcome to post in this forum looking for up-to-date information.
