Is it possible to add the ability to request cue names using cue list / cue number
for example
/eos/out/get/cue/1/1/label
or similar
for example
or similar
Eos will send all the time the cues and its Labels.
see right here while i hit Go:
and the cuelist for this:
And if you have a look in the EosFamily_ShowControl_UserGuide_RevC.pdf, starting from page 72, you will find your 'get' with all the information of the requestet cue-information.
Maybe this is a little bit helpfull.
this does work, but only if you run the cue, i want to be able to just get the cue label
and the get on page 72 is more complicated than what i was looking for and requires multiple steps
Regarding the Manual on Page 69, a simple
/eos/get/cue/1/11
will give you a quite nice and short information.
As you can see here
you still need to filter your information from the answer. But it is quite obvious for the naked eye
